97 lt1 head ans cam swap
Old Dec 21, 2011 | 03:56 AM
30Z28BLACK's Avatar
I was thinking of doing a head and cam upgrade I have a stock 97 z28 with some bolt ons. was going to upgrade rear gear to 3.73 and was lookin at the trick flow set up on summit(heads/cam rollers) the cam seems to be the same as the gm hot cam. any body use this set up or is there a better option for around the same price. The car is hopefully going to be a street/strip so don't want anything to crazy.
Old Dec 21, 2011 | 05:20 AM
Re: 97 lt1 head ans cam swap
Have your stock LT1 heads ported by a shop with a proven track record, and let them supply a matching cam, based on your specific plans for using the car, and your budget.
Advanced Induction - LTx Performance Parts
http://www.elliottsportworks.com/
Total Engine Airflow | CNC Ported Cylinder Heads | GM - LT1/LT4 | CNC Porting | Cylinder Head Engine 44278 | CNC Cylinder Heads Tallmadge | CNC Ported | CNC Head Porting | Custom Cylinder Head | Ohio | :: Total Engine Airflow ::
Old Dec 22, 2011 | 11:03 PM
Bersaglieri's Avatar
I'm with Injuneer on this one. Call and speak with each of the companies he listed and see which one fits your power and budget needs. Lloyd Elliott has worked well for me. I know many people who have had good luck with each of those companies. However I don't see many folks using TEA for cam selection.
Harland Sharp is a good budget rocker, made in Ohio, long time performance company, and lifetime warranty. I've always had good luck with Comp rockers. I've used Pro Mag, Stainless Pro Mag, and Ultra Pro Mag with zero problems. Stay away from anything "too good to be true" price wise. Most of that stuff in junk chinese stuff.
-Dustin-
oldschool
Feb 9, 2016 09:21 PM
birdblack
Dec 30, 2014 06:59 PM
chuyz28
Nov 25, 2014 11:14 PM
Queens94z28
Nov 20, 2014 06:03 PM
NED4SPD
Sep 16, 2002 10:45 PM
