97 Clutch master,slave, or other problem
Old Jan 26, 2003 | 04:01 AM
  #16
LT1derful's Avatar
Originally posted by auslandt
Well back to the subject at hand. Prior to investigating the clutch, it looks like the soft pedal/clutch problem is due to a broken slave cylinder. The slave is NOT leaking so the Hydrolics are intact. The problem is that when the master is pushing the slave, the slave mounting is broken and allowing the slave housing to push backward some instead of the enitre force pushing the fork forward. Oh well... I wanted a performance clutch anyway.
That's exactly what happened in my case, and exactly what I went thru. Was time for a new clutch...so I bought one, wasn't the OVERALL problem, as master/slave was...but, needed one anyway.
Hey...and I was RIGHT in my initial diagnosis. Thought your problem sounded a lot like mine!
Oh, and funny...I replaced my rear pinion seal while I was at it, too.
DJ
Old Feb 3, 2003 | 11:36 PM
  #17
auslandt's Avatar
Cool
Absolute final diagnosis.... Slave Cylinder.
The clutch disc and PP were ok. All springs in place and at least 1mm wear left on both sides. PP intact and looking ok. Flywheel looked very good with a couple of "hot" rings. No hot spots.
Just turned the flywheel, putting in the new clutch, should be good to go once I get the steam pipes taken care of and can then put the transmission back on.
Old Feb 4, 2003 | 01:43 AM
  #18
LT1derful's Avatar
I certainly thought your situation sounded ALL TOO familiar to me...again, I went thru it. Glad to see everything looks OK elsewhere.
DJ
Old Feb 4, 2003 | 12:34 PM
  #19
JeffK95Z's Avatar
Great posting guys!!
I love to see stuff like this and the orginanators updating their findings and giving everyone a absolute final diagnosis...
I have a simiar problem (clutch pedal is fine, but hard to get into gear AT TIMES... not always... its weird...) so I'll be reviewing all this stuff again, and checking what I can...
Thanks for all your work on this!!
Jeff
Old Feb 4, 2003 | 01:27 PM
  #20
auslandt's Avatar
Jeff
Glad to be of service. Let my pain be your pill.
The first thing I always check with hydrolic clutches is the fluid level. I had an old toyota that would leak at the master cylinder slowly. Overtime the clutch would no longer work. So once I found that, I kept a bottle of brake fluid in the car. Not really worth fixing until it went REALLY bad. I only sold the car for $350.
Ringmaster72
Mar 19, 2015 03:32 PM
BPS
9
Mar 5, 2015 10:51 PM
HectorM52
Jan 30, 2015 11:08 PM
siguy
Nov 27, 2014 10:07 AM
