97 Camaro Z28
Old Sep 13, 2004 | 06:40 PM
HYRIDEJEEP's Avatar
97 Camaro Z28
I was driving one today & the low coolant light came on it was running warm, the gauge said 210 -220 sitting at the light but would drop to about 185- 190 while driving. So I got it home & turned it off & it started puking antifreeze out the overflow cap. The antifreeze was like a bronze color. Do they even make such a bronze color antifreeze, or does it have more problems? Then the tranny started shifting hard when it was running warm. I went back out there & drove it around for about 15 min & the coolant light was off but it started running a little warm & it was shifting softer but it didn't puke anymore antifreeze up. The coolant is full.
Thanks for your alls help
I'm new at the camaro scene.
Bill
Old Sep 13, 2004 | 07:26 PM
Kataklysm's Avatar
Re: 97 Camaro Z28
No they don't make a bronze antifreeze for these cars, your coolant is old and needs to be changed to maintain proper cooling. The cars always shift kinda hard, if you think its shifting harder due to it being warm install a transmission cooler, it's one of the best things for an automatic transmission.
Old Sep 13, 2004 | 08:49 PM
68z28's Avatar
Lightbulb Re: 97 Camaro Z28
what about dexcool? Dexcool is an orangish bronze color. Im not sure what year GM started using this coolant but maybe thats what the bronze stuff is. I kno the dexcool came later than 95.
Old Sep 13, 2004 | 09:19 PM
HYRIDEJEEP's Avatar
Re: 97 Camaro Z28
Originally Posted by MarkyMark
The 97 camaro has the lt1 engine in it, so it'd be more proper to post in the general tech or lt1 tech forum....fyi 98-02 has the ls1 engine in it. Someone in this forum I'm sure could help you, but I'm just letting ya know man.
I'm sorry I thought I clicked the LT1 forum. I posted it over there now. I thought I seen some stuff in a tube that was stop leak & it was bronze, but I wouldn't think that a tube of that would turn it bronze Someone over on the LT1 board said that Dexcool is orange.
I drove it again & the service engine light came on
I just hope something major isn't wrong with it. Anyways the dealership said they would take care of the problem.
I'd just like to learn as much as I can for a little arsenol for tomorrow morning
thanks guys
& once again sorry for clicking the wrong forum
Bill
Old Sep 14, 2004 | 04:15 AM
BirchMan98z's Avatar
Re: 97 Camaro Z28
some coolant is a reddish/orange color, Yes. That's not saying that yours wasn't green at one time, but, it could help you breathe a little easier. I have a hard time thinking that all those gallons of coolant could turn bronze like that... there would be SOME trace of green if you were using regular antifreeze.
Old Sep 14, 2004 | 05:02 AM
AL SS590 M6's Avatar
Moderator
Re: 97 Camaro Z28
I'll move it for you.
Old Sep 14, 2004 | 06:06 AM
Dave C. '97 Z28's Avatar
Re: 97 Camaro Z28
My 1997 came with Dex-cool. It's a dark orange color.
-Dave C. '97 Z28
PS: Check to make sure your fans are coming on. If they are, then check your thermostat.
Old Sep 14, 2004 | 06:14 AM
Jon97Z's Avatar
Re: 97 Camaro Z28
Every later model Z28/TA I've ever seen came with Dexcool. There's a lot of mixed opinions on this board as to which is better, but yes, after a year or two of use it does have a 'bronze' sort of color to it. You could also be do for a flush. Generally, I try to change mine once a year. But you'll hear different opinions on that too.
As mentioned before, I would start with the small stuff. Check your stat, fans and then go from there.
CamaroHeed
Mar 18, 2020 09:50 PM
NewsBot
Dec 28, 2014 06:20 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
grendal
Apr 15, 2010 05:20 PM
2000silverz28
Jul 20, 2002 06:14 AM
