96 Z28 normal temp?
96 Z28 normal temp?
Hey, I have a 96 Z28 and I'm just wondering any of you out there that have 96 or similar years what's your cars running temp range? Like when cruising and how hi does it get when idle? Thanx for the info!
With a 160-thermostat and reprogrammed fans, my car runs at 170 all day.
With stock programming and a stock thermostat, our cars are designed to run hot. The stock cooling fans don't come on until 227 degrees (235 degrees for the high speed). Temps will obviously be cooler at speed and warmer at idle.
When cruising, the temp stays at the first mark above 160*(~190). When idling with no motion....the thing will get as hot as 230* before the fans pull it back down to around 210* or so.
Jul 4, 2005 05:00 PM
