96 z28 gen 4 swap 1 gen 350
Re: 96 z28 gen 4 swap 1 gen 350
Need quite a bit more info.
Carb or EFI? If EFI, what aftermarket computer? Distributor ignition? Trans type? Retaining stock dash, including speedometer and tach (these interface with the PCM)? Do you require retention of the windshield wipers? What intake manifold and carb or throttle body? Do you want to retain stock hood? LT1 radiator or aftermarket?
F'n1996Z28SS
Aug 23, 2023 11:19 PM
