96' Roadmaster engine into 95' T/A..Problems?
I just bought a really clean 75K Miles 96 Roadmaster LT1 for my 95 trans am that has a spun bearing and was wondering if I will have any problems hooking it up to my current wiring harness and accessories? I know that it has iron heads also. I am considering swapping my hotcam, alum heads, and timing chain over to this motor but I dont know if I can do it all in one weekend.
I know it will be much easier but I have to have the car driving so I can take it to work next tuesday. My current daily driver Mark VIII is wrecked and not running. I am afraid that something will go wrong in the cam or head swap
I think it was Hertz that told me that. I need some roller rockers now. Can I just get some SA Comp Pro Mags and put them on with the stock head studs, hotcam springs, and stock pushrods and lifters?
Might consider leaving the iron heads on so your aluminums are sitting on a shelf awaiting porting when you should have the will and money.
The iron heads flow more than your aluminums anyway and with just a HOT cam the pressed studs are OK.
Only snag with using the HOT cam under the iron heads would be the springs you have are unlikely to fit the iron heads so you might have to buy springs.
This way if and when you decide to do ported heads you will minimize downtime then and for now there is no real downside to the iron heads other than needing springs and they are heavier. IMO though 40-45lbs of weight on a what 3600+lbs street car is of little concern.
I was thinking I would just drive it like this for a while and then send the spare alum heads to Ai and get their 200CC CNC porting done, a solid roller (or big BRE w/ caddillac lifters), Ai ported intake, a scat forged 355, and then add a Nitrous Outlet "Money Maker" set to 225-300
with a progressive controller. Then I would like to swap it to a 4L60E w/ a big stall and put that T56 and stock headed hotcammed LT1 in my caprice wagon.
Whats the most I can rev these SA Comp Pro mags I just bought to?
with a progressive controller. Then I would like to swap it to a 4L60E w/ a big stall and put that T56 and stock headed hotcammed LT1 in my caprice wagon. Whats the most I can rev these SA Comp Pro mags I just bought to?
JasonD
Aug 23, 2010 03:14 PM
redzed
Aug 31, 2002 01:00 AM
Caps94ZODG
22
Jul 30, 2002 08:45 AM
