96 Lt1 Ecu
Old Jun 23, 2006 | 12:27 PM
blackk96z28's Avatar
96 Lt1 Ecu
Need stock flash tuned put on ECU...for some reason my ECU is not telling my cooling fans to turn on..had shop run diagnostic and that is what they came up with....any help would be appreciated....thanks
Old Jun 23, 2006 | 01:16 PM
OBE1 95Z28's Avatar
Re: 96 Lt1 Ecu
Have you have the computer out (unplugged)? If so, the connections may cause your issue; reseat the connectors and push to seat them all the way down.
Also verify that your computer is seeing the correct temp reading from the temp sensor (not the same sensor as the dash gauge).
Old Jun 23, 2006 | 03:19 PM
fast96lt4's Avatar
Re: 96 Lt1 Ecu
checked the relay?
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
oldschool
Feb 9, 2016 09:21 PM
Jonnybegood
Parts Wanted
Feb 10, 2015 07:50 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
