96 keyed crank hub with washer???
Old Nov 6, 2003 | 06:11 PM
BlackDog's Avatar
I was reading thru some of the posts that the 96 crank hub is keyed vs. the 94. I've also read that the 96 hub is a little shorter.
I know that you can buy a keyed hub but I would like to save a few bucks if I can.
Is it possible to use the 96 hub on the 94 with the correct size washer? Also does the washer have to be keyed as well?
Can this washer be bought some where?
Thanks,
Scott
Old Nov 6, 2003 | 06:26 PM
aram's Avatar
pretty sure none of them are keyed.. only crankshaft has a keyway. I wouldnt want to mess with a washer or anything on the hub. I'd just buy a keyed hub or fluidampr/ati damper.
Old Nov 6, 2003 | 06:28 PM
No factory LT1 hubs are keyed (any year). If you wanted to use a 96> hub on a pre 96, you would need a spacer that is equivalent to the thickness of the reluctor used for the crank position sensor used on the 96> engines. That spacer would likely need to be keyed like the crank timing gear.
Old Nov 6, 2003 | 06:47 PM
RiceETR96's Avatar
I just ordered a Keyed hub for my engine. Now its a 96, is there gonna be a problem if the keyed hub is not a 96 hub that they put a key way in?
Old Nov 6, 2003 | 07:18 PM
BlackDog's Avatar
I guess I miss read the post about the 96 hub. Oh well, I'll just have to buy one.
Thanks for the info guys.
Scott
mightymouse383
Jul 20, 2016 07:34 AM
cyteone
Feb 7, 2015 06:04 PM
Chevyguy358
Jan 28, 2015 08:04 PM
