96 corvette motor into 95 trash can, need help quick!
Old Jul 14, 2007 | 11:24 AM
IgorT.455/406's Avatar
Hey guys,
There is a 96 factory corvette lt1 crate longblock for sale locally.
I have a 95 Trans Am with a rod knock. I'm considering this vette longblock, but am curious if all my accessories, brackets, and all the tin will boltup to the vette block.
So mine is 95 F body, crate motor is 96 lt1 Y body.
Will everything bolt up, or, will I need new stuff? If so what?
Thanks.
Old Jul 14, 2007 | 03:26 PM
96ZCamaro's Avatar
I beleive the only difference between the blocks themselfs are the mains. I think the corvette blocks come with 4 bolt mains to where as the fbodys only have 2 bolt mains. So I do not see why it would not go in without modification.
Old Jul 14, 2007 | 04:06 PM
87camracer's Avatar
Being that it's a 96 motor, you might check and see if its an LT4 or not. That would be a nice surprise.
Old Jul 14, 2007 | 04:11 PM
a walker's Avatar
I'm not 100 % sure this is correct, but I think the y body oil pan and crank hub and/or balancer are different. All the f car stuff will work fine on that engine though.
Old Jul 14, 2007 | 07:21 PM
custom95's Avatar
a walker is correct, harmonic balancer is different. You should be able to swap all of your f-body accessories and stuff onto that motor with no problems.
edit: a walker is also correct on the oil pan. the pickup tube is different too, but once again, just take all of the crap off of your motor and swap it onto the vette motor.
Feffman
Oct 9, 2015 05:42 AM
NewsBot
Mar 11, 2015 11:20 AM
armedtrigger
Feb 24, 2015 08:30 PM
bonniew
Events and Cruise Spots
Jan 18, 2015 01:14 PM
guionM
14
Jun 19, 2002 08:30 AM
