96 camaro wont start
Old Jul 20, 2010 | 11:30 AM
shawnoltr450's Avatar
i just bought a 96 camaro and it ran great until sunday night it wouldn't start i thought that it was the starter but i boosted it with another car and it started but now the fuel pump wont turn on and neither will the nash light or gauges unless you really play with the key than the gauges will light up but still wont start
Old Jul 20, 2010 | 11:51 AM
n2ceptor's Avatar
Have the battery checked....
Old Jul 20, 2010 | 05:16 PM
the battery is fine i took it out and put one in that i know that works and it didnt do anything i think that it may be the ignition switch but not to sure
Old Jul 20, 2010 | 05:51 PM
94CamaroZ28/SSClone's Avatar
Vats System? Is the "Security" Light on?
Old Jul 20, 2010 | 07:45 PM
no security light is not on but it was set off before all of this happened and that box under the dash on the passenger side keeps ticking
Old Jul 20, 2010 | 07:50 PM
ACE1252's Avatar
Does the security light blink when you turn the key to try and start the car?
Old Jul 20, 2010 | 07:52 PM
If it was set off before it stop turning on, I might say it has something to do with the Vats System. I had sort of the same problem on my 94 Z28. My ignition went bad, so the chip key wasn't sending the signal to the Vats. Which in turn, would not let me turn on the Camaro.
Old Jul 20, 2010 | 09:43 PM
CstIrnFst's Avatar
If you'd like more info on the security system, here's a link to shoebox's website regarding the VATS:
http://shbox.com/1/pass_key.html
I'm not positive that's the way to go on this one though.
Old Jul 21, 2010 | 05:45 AM
if the chip is not working will all the gauges not work and the fuel pump not come on if so thats what im dealing with
Old Jul 23, 2010 | 07:34 AM
the camaro lives again after all that it was a ground in that little box just behind the battery cleaned that up and good to go
ChrisFrez
Dec 7, 2014 06:01 PM
globalprojeff
Dec 6, 2014 04:18 PM
NewsBot
Dec 3, 2014 12:30 PM
ChrisFrez
Nov 23, 2014 10:33 AM
Jul 4, 2005 05:00 PM
