96 Camaro SS hard start, stalling
Old Feb 19, 2014 | 04:45 PM
vshotrod's Avatar
96 SS #949 6-sp, problems starting and stalling. Over last few weeks car has been dieing randomly when driving, no pattern, sometimes at stop and sometimes while driving, always started back up and kept driving. Now it is not starting, or when it does start its a very rough idle until it stalls, usally 10 - 15 seconds, then cranks but no start? I hear the fuel pump each time, have fuel at the schader valve. replaced fuel pump 3 months ago along with new fuel filter, fuel pump relay and fuel pressure regulator, new spark plugs, was running great?
Old Feb 19, 2014 | 05:43 PM
blackblur1996z28's Avatar
Re: 96 Camaro SS hard start, stalling
How many miles on your opti? When you changed your spark plugs did you check your plug wires? Any dtc codes?
Old Feb 19, 2014 | 07:17 PM
At any point in this process have you actually measured the fuel pressure?
Old Feb 23, 2014 | 01:56 AM
vshotrod's Avatar
Car has 44k original miles, plug wires looked good, fuel pressure at 43, no codes.
Old Feb 23, 2014 | 05:00 AM
97WS6SCharged's Avatar
What fuel pressure regulator did you use?
Old Feb 25, 2014 | 12:44 PM
SuperSportSS's Avatar
had a similar problem on my old 1995 #133 firehawk, after replacing the fuel pressure regulator it would run fine then blow up the regulator again and again, come to find out it was the little vent on the gastank lines, you know the one thats just sitting into a bracket inbetween the rear end and gas tank? cost me $12 to fix, and never had a problem again
Noenav
Mar 1, 2019 07:38 AM
Red97LT1
9
Dec 17, 2014 06:13 PM
jayblev95
Dec 1, 2014 06:55 AM
thenewkid
Nov 27, 2014 09:41 AM
Klypto
Jul 19, 2002 07:25 AM
