95z28 Starts then dies. HELP!
Old Jun 1, 2007 | 07:35 AM
lt1car's Avatar
The car starts and runs ruff for 3 seconds then dies. If I give it gas it revs up for the same 3 seconds and dies. Seems like the computer or something is not giving it fuel to run more the 3 seconds.
I checked:
All Fuses
Unpluged maf, then repluged maf
Checked all vacuum lines
unpluged battery and reset it
I do have the VATS disabled. I bought a 3 wire pc of ebay that plugs into the PCM. That worked for a long time, now it seems like its doing the same thing. Could the connections be bad to that again? Or could it be my opti or fuel pump? Car has 117k miles.
Thanks for the Help!
Joe
Old Jun 1, 2007 | 07:47 AM
Nitelite's Avatar
Try checking the fuel pressure when you turn the key on, and while it is running for the 3 seconds. The pump may be throwing fits and is just trying to hold on.
Old Jun 7, 2007 | 12:57 PM
lt1car's Avatar
still not working any help?
Old Jun 7, 2007 | 01:05 PM
2000GTP's Avatar
Did you do the above suggestion and check the fuel pressure at the rail?
Old Jun 7, 2007 | 09:16 PM
z275plus's Avatar
Mine did the same thing turned out to be my fuel pump.I also replaced the fuel pressure regulator just for good measure,runs fine know.
cobrakilling101
14
Mar 17, 2015 10:42 AM
Oncomingstorm22
Jan 22, 2015 07:15 PM
Amshnock
14
Jan 18, 2015 11:47 AM
RichJ
Sep 26, 2002 09:43 AM
Black Sunshine/ 00SS
Aug 24, 2002 03:41 PM
