95z runs bad when cold
Old Jul 3, 2007 | 10:39 PM
dhz28's Avatar
car runs ruff ,no power and will back fire when cold. after 3 or 4 min. of driving the car will scream. I HAVE 114,000 miles on sensors 500 on rebuild. had problem before rebuild. put trick flow elbow on, stock elbow had tear.
Old Jul 3, 2007 | 11:18 PM
MysticTeal95Z28's Avatar
Try cleaning your Mass Air Flow sensor and see what happens.
Old Jul 4, 2007 | 01:23 AM
mrmint69's Avatar
I always let my car warm up for 6-7 minutes and run it soft for another 5 so i have no idea if it would have this problem. I would guess the car is not getting enough air until the car warms, so a sensor is probably dirty or bad. I know my A4 shifts funny and it seems to be lacking full power until it is good and warm.
Old Jul 4, 2007 | 05:05 AM
BoogieZ28's Avatar
Replaced cap and rotor? It should be changed at 100k miles, if you haven't that might be your problem. I had a similar problem, ruff and no power, changed opti spark cap n' rotor, problem solved.
Old Jul 4, 2007 | 11:42 AM
Check the coolant temp sensor.
Old Jul 4, 2007 | 12:48 PM
96ZCamaro's Avatar
Totaly agree with Injuneer. I would check that first.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Amshnock
14
Jan 18, 2015 11:47 AM
Britbilly
Jan 7, 2015 08:49 PM
jayblev95
Dec 1, 2014 06:55 AM
