95Z failed emissions, again!
Old Jan 12, 2014 | 08:50 AM
Hector95Z28's Avatar
Lt1 was down for 4/5 months, finally replaced the Opti and now its running again. Problem is, took it to get the emission test and it failed again. The problem being high NOX. NOX came in at 2.20, allowed is 2.0. I unplugged the coolant sensor due to it being faulty sometime ago to remove the notification of low coolant on the dash. Will this act alone, cause me to fail emissions?
Old Jan 12, 2014 | 10:11 AM
Kevin Blown 95 TA's Avatar
Re: 95Z failed emissions, again!
If you have an aftermarket cat on there, see if you can put a stock one on for the test. Back when I was going though all that, the stock cat was way better on HC, CO, and NOX than the aftermarket one that was only a year old.
If you have a known good stock cat on there, then egr not working, engine temp to high, timing too advanced...
Old Jan 12, 2014 | 10:34 AM
The low coolant sensor would have no effect. It is just a light on the dash. No computer interaction whatsoever.
Jeff1904
Jun 5, 2016 05:00 PM
damnyankee36
Sep 9, 2015 07:06 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
sherwinZ28
11
Aug 15, 2015 05:38 PM
Boss002
Jul 24, 2015 10:47 AM
