'95 Z28 Vacuum Check Valve Needed!
Old Sep 23, 2018 | 04:16 PM
Michael Asher's Avatar
I have been looking all over for a check valve for this thing! I cant trust the internet too well because a few other places I got it from didnt fit the lines. Would I be able to run well without it?
It's the check valve on the drivers side of the engine closest to the intake, originally blue and white.
http://shbox.com/1/opti_vacuum_hose.jpg
Last edited by Michael Asher; Sep 24, 2018 at 03:21 AM. Reason: The check valve on the right
Old Sep 23, 2018 | 08:20 PM
Re: '95 Z28 Vacuum Check Valve Needed!
Check valve for what..... AIR manifold connections, A/C control vacuum line, Opti vent line?
Old Sep 24, 2018 | 03:22 AM
It's the check valve on the far right.
Old Sep 24, 2018 | 12:21 PM
Chimera96's Avatar
For the Opti vent harness, You could pick one from a junkyard
Doorman makes some. IIRC this is the larger one closer to front of engine. On the same page they show others...maybe the Delco one would replace the smaller rear one
Amazon Amazon
Old Sep 24, 2018 | 01:45 PM
If you run without the vacuum check valve in the Opti vent line, you might run the risk of a backfire in the intake manifold pressurizing the Opti case.
Is yours physically damaged or does it simply not work when you blow through it?
Old Sep 24, 2018 | 04:18 PM
Pullngz's Avatar
Any auto parts store should have one. It just prevents flow from the intake to the opti, yet allows air to flow from opti to intake.
Old Sep 25, 2018 | 02:12 PM
The one from the store doesnt fit the lines. I ordered one from doorman, itll be here tomorrow. Someone helping me work on the car broke the stem to it at the base.
Old Sep 25, 2018 | 07:12 PM
Pullngz's Avatar
Just broke the stem? Super glue it back together.
DLLJ
Jun 17, 2013 08:35 AM
deerslayinrenek
Parts Wanted
Jun 15, 2011 10:30 AM
eanhl2004
May 23, 2009 03:46 PM
km9v
Feb 20, 2007 04:14 PM
X-Jester
Aug 7, 2003 10:07 PM
