95 z28 lt1
Old Sep 26, 2010 | 08:53 AM
junglejim11's Avatar
95 z28 lt1
I've been having engine shaking at idle and in gear and when i take off, it is intermitantly rough thru low r.p.m.'s and smooths out in hire r.p.m.'s. i also have had some back firing and some lifter taps. Please help!!!!
Old Sep 26, 2010 | 09:01 AM
Please help!!! My 95 z28 shakes in idol and in gear and runs rough at lower r.p.m.'s and runs better at higher r.p.m.'s. Some times it backfires with lifter taping at lower r.p.m.s.
Old Sep 26, 2010 | 12:22 PM
brandons94lt1's Avatar
Do u have a diagnostic program or a scanner? That would help u verify that ur o2 sensors r operating correctly, and some let u see if the low and high res signals are being sent from the opti. If not, then start with the usual, any work been done to the car lately? How r the plug wires? Check and make sure they're connected not just on the plug and especially @ the opti. Check for vac leaks, any ses codes? Did it just start all of a sudden? Loose vac lines, a leaky intake manifold, a bad ground, a bad opti, bad or clogged injector, lots of variables. When my car started doin that I went through everything, from the map to the cam lobes possibly getting worn flat, turned out to bethe connection @ the opti for #6 plug wire. Hope this helps
Old Sep 27, 2010 | 05:34 PM
ANARCHY510's Avatar
im having these exact problems was told it might be the opti going out. let me know if you find the problem.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
cmdeshon
Jan 4, 2015 11:15 AM
Brandon Wittmer
Dec 3, 2014 09:28 PM
Jul 4, 2005 05:00 PM
