95 z28 lt1
95 z28 lt1
I've been having engine shaking at idle and in gear and when i take off, it is intermitantly rough thru low r.p.m.'s and smooths out in hire r.p.m.'s. i also have had some back firing and some lifter taps. Please help!!!!
Do u have a diagnostic program or a scanner? That would help u verify that ur o2 sensors r operating correctly, and some let u see if the low and high res signals are being sent from the opti. If not, then start with the usual, any work been done to the car lately? How r the plug wires? Check and make sure they're connected not just on the plug and especially @ the opti. Check for vac leaks, any ses codes? Did it just start all of a sudden? Loose vac lines, a leaky intake manifold, a bad ground, a bad opti, bad or clogged injector, lots of variables. When my car started doin that I went through everything, from the map to the cam lobes possibly getting worn flat, turned out to bethe connection @ the opti for #6 plug wire. Hope this helps
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
Jul 4, 2005 05:00 PM
