95 z28 camaro rebuilt lt1 noise issues
Old Apr 28, 2018 | 08:34 PM
Humblelt1's Avatar
Hi im new to the forums. i got a rebuilt lt1 in a 95 z28 cc503, scorpion rockers 1.5 rebuilt bottom end. but it makes noise and i can't figure out what it is. will upload video. Sorry for not posting in lt1 tech
Old Apr 30, 2018 | 12:24 PM
DrewHMS97SS's Avatar
Re: 95 z28 camaro rebuilt lt1 noise issues
That sounds like a loose rocker to me. Have you pulled the valve cover and checked the rocker adjustment?
Old Apr 30, 2018 | 02:37 PM
Chimera96's Avatar
OP
did you trim the braces on the Valve Covers for the roller rockers?
if not you need to (intake side)....if you did than the valve lash sounds really off
Attached Thumbnails 95 z28 camaro rebuilt lt1 noise issues-valve_c_mod-intake-side.jpg
Old May 1, 2018 | 01:42 PM
Humblelt1's Avatar
I adjusted the rockers poly locks. Hand tight then 1/8th to 1/4 turn. And yes I did trim the valve covers. New clutch even ran without valve covers. Still makes the noise.
Old May 1, 2018 | 02:31 PM
I know some lifters require a bit of different adjustment, do you know what lifters are installed?
Old May 1, 2018 | 04:44 PM
Chimera96's Avatar
OP
if that noise is not from anything hitting VC...the valve lash is WAY off.
what method are you using to adjust valve lash?
when you do have the lifter of the particular cyl/valve you are working on sitting on base circle of cam you just tighten polly nut with fingers just till it touches/stops with the very slightest of effort. That is zero lash. If you have regular lifters you then turn 1/2 to 3/4 more turn (preload) then tighten the alan screw while holding poly nut in place. Repeat for each valve
If you have short travel lifters like Comp 875's you only tighten Ploy 1/8 turn MAX
Old May 1, 2018 | 08:58 PM
Sounds like a rod bearing to me.
Old May 1, 2018 | 09:16 PM
Humblelt1's Avatar
They are scorpion rockers. So I’m not really sure what lifters are in the motor but I’m assuming comps cause the cam is comp cam 503. I assume I understand hand tighten rocker then tighten poly locks with less then 1/8th pre load? I thought just being to tight would cause loss of compression not valve train noise?
Old May 1, 2018 | 09:30 PM
Chimera96's Avatar
how are you determining the valve you are lashing, that lifter is on the base circle of cam?
Old May 2, 2018 | 07:47 AM
Humblelt1's Avatar
Sorry basically make sure Intake valve is open then do the exhaust valve lash. And repeat on rest of cylinders. Am I doing that correct? Also shoebox I hope your wrong but there is no metal in the oil besides break in in. But just to be certain as well I’m probably going to be pulling the oil pan this weekend.
Old May 2, 2018 | 10:13 AM
It is hard to say without knowing the lifter. The Comp R lifters are supposed be adjusted to zero lash, but in their documentation the guide states you need to reference the lifter to find the correct pre-load: COMP Cams® - Lifter Technical Reference
Old May 2, 2018 | 10:24 AM
Chimera96's Avatar
OP
if you are doing the EOIC lash method correctly than the valve train should not sound like that...assuming you did lash correctly...you have some serious metal to metal contact going on inside the engine
Video just sounds like serious valve lash issue or RR hitting the valve covers or something in rotating assembly hitting something
Any of the above will kill the motor quickly
Old May 2, 2018 | 10:28 AM
Originally Posted by Chimera96
OP
Does it sound to you from the video that the noise is more predominant from the passenger side though? Wouldn't that point more to something with the rockers/lifters?
Old May 2, 2018 | 01:15 PM
Humblelt1's Avatar
Yes it is dominant on the passenger side. I’m going to try and get a video later to day of what it sounds like warmed up. It knocks then pauses it strange.
Old May 2, 2018 | 02:01 PM
Chimera96's Avatar
OP
have you taken the valve covers off and looked for any signs of witness marks?
The noise sounds like valve train...but its a cell phone video on the internet
