95 Z28 Camaro ignition module
Old Oct 7, 2003 | 09:04 PM
Fred Jeter's Avatar
Talking 95 Z28 Camaro ignition module
What is the function of an iginition module on a 95 Z28 Camaro? My car is coding 36 and 42, and i need a fix.
Old Oct 7, 2003 | 09:30 PM
The ICM takes pulses from the pcm and then directs the coil to fire. Your code 36 is a faulty high resolution pulse or extra low resolution pulse from the opti. The ICM can't cause that. Sometimes a hiccup from the opti will also cause the code 42 from the ICM.
Oh, you might want to delete the duplicate thread.
Old Oct 7, 2003 | 10:15 PM
Fred Jeter's Avatar
Talking code 36 and 42
Thanks for your reply. Do you think i should replace my opt-spark at this time?
Old Oct 7, 2003 | 10:22 PM
Re: code 36 and 42
How bad/often is it acting up? The engine will continue to run unless the problem is pretty bad.
Check the electrical connections to the opti. The one on the opti, itself, can sometimes get corroded. Look with a light, down into the opti.
Old Oct 7, 2003 | 10:31 PM
Fred Jeter's Avatar
I installed that opt-spark about 2 months ago. since the installation, my car rpm guage will bound a little from time to time. My car idle at 1000rpm, but it will fall a little lower. It seems like i have a miss, but its not bad; however, i can tell that its happening.
Old Oct 7, 2003 | 10:39 PM
Re: code 36 and 42
Was it a complete GM opti?
Old Oct 7, 2003 | 10:42 PM
Fred Jeter's Avatar
code 36 and 42
I bought it complete from Auto Zone for $130.00. It looks just like the original one i took off.
94Z28LS1toLT1
Jul 10, 2024 05:17 PM
Ari G
Dec 11, 2014 03:21 PM
thenewkid
Nov 27, 2014 09:41 AM
Jul 4, 2005 05:00 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
