95 Z28 A.C. Delete
Old Oct 4, 2011 | 09:10 AM
Airtime2877's Avatar
95 Z28 A.C. Delete
Hi All,
When I purchased my 95 Z28 It had a bad motor which I have now replaced with another LT1 with 65K on it. I alos discovered that the AC compressor was locked up. I removed it along with the AC lines and the evaporator/Dryer. Should I also remove the condensor in front of the radiator. will this allow for better cooling? I am doing the distributer today since the remaned one that came with the engine failed last week and I thought it would be a good time to remove the condensor if that makes sence.
Thanks in advance for your help,
Airtime
Old Oct 4, 2011 | 11:05 AM
calaban's Avatar
Re: 95 Z28 A.C. Delete
You don't need it for the AC anymore, you'll lose a little bit of weight, and as you said it may block some air flow to the radiator.
Go for it.
Old Oct 4, 2011 | 05:10 PM
punkslapper's Avatar
Go for it.
+1,, Get a delete pully from Summit and roll out.
Noenav
Mar 1, 2019 07:38 AM
ModdedNerd
Feb 5, 2015 04:37 AM
k1996z28
Jan 21, 2015 07:22 AM
DropZ
Jan 15, 2015 10:40 AM
