Air Pump ??
Old Oct 4, 2011 | 08:22 PM
MrHyde's Avatar
Air Pump ??
would a Air-pump failure cause the motor to rough idle ??
Old Oct 4, 2011 | 08:28 PM
JGuy07's Avatar
Re: Air Pump ??
I don't believe it would, since it usually only pumps air through the lines on start up and for the first few minutes until the temps are up. I don't think it would actually effect idle anyways. The air goes from the pump, to the valves which I believe only allow the air to flow into the manifold and then out through the exhaust system. It shouldn't bother the idle at all.
Old Oct 4, 2011 | 10:28 PM
nintythreeZ28's Avatar
Re: Air Pump ??
i dont believe it would cause mine is deleted totally and runs like a champ
HectorM52
Jul 30, 2017 11:46 AM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
Magenta_Hearts
Mar 22, 2015 03:36 PM
Magenta_Hearts
Mar 5, 2015 07:01 AM
