95 speed
Old Jun 24, 2013 | 12:46 AM
vhtony's Avatar
95 speed
Got a 95 z28 6 speed v-8 engine that wont go over 90, anyone know why?
Old Jun 24, 2013 | 12:56 AM
SSSean's Avatar
Re: 95 speed
what is it doing? lacking fuel or air or electrical issues? What are some symptoms drive-ability issues?
Old Jun 24, 2013 | 01:40 AM
slick1hunting's Avatar
does it run strong up until then? If so might be speed regulated somehow(might be able to in the tune) I know all the rentals ive had thats been regulated at the 90-100 mark
Posted from Camaroz28.com App for Android
Old Jun 24, 2013 | 05:30 AM
Shangrila's Avatar
Re: 95 speed
So where did you find this out?
Old Jun 24, 2013 | 08:24 AM
Re: 95 speed
So broad a question without any details is impossible to answer.
Old Jun 24, 2013 | 11:24 AM
moparman's Avatar
Re: 95 speed
There were LT1 cars that had a speed limiter. The ones that didn't come with Z rated tires. They also got a 120MPH speedo instead of the 155.
Old Jun 24, 2013 | 01:07 PM
vhtony's Avatar
Re: 95 speed
it doesn't have any issues other than that, i found out on a track out where i live and it runs super strong up until then, it still is only at 2 or less rpms then it just wont go any higher, it was really weird.
Old Jun 24, 2013 | 01:13 PM
KW Baraka's Avatar
Re: 95 speed
There could be 100 reasons why the car won't go past 90mph......BUT.....the most likely culprits are:
1. Your valve springs are weak and your valves are floating;
......or, and most likely......
2. Your PCM has been programmed by a previous owner to limit the speed at 90mph.
KW
Old Jun 24, 2013 | 01:17 PM
vhtony's Avatar
Re: 95 speed
is there a way to bypass or get the limit raised? or completely removed?
Old Jun 24, 2013 | 01:20 PM
Re: 95 speed
Exactly what happens when you reach 90 MPH? Does it just shut off, like the fuel got shut off? Or does it start to misfire, stumble, etc?
You indicate you are "only at 2 or less rpms".... do you actually mean 2,000 RPM (the numbers on the face of the tach get multiplied X 1000). To be at 2,000 RPM with a T56 and the stock 3.42 rear axle ratio, you would have to be in 6th gear. That's not the way to get it over 90 MPH, and I can't conceive of any reason you would use 6th gear at the track.
Shift out of each gear at about 5,500 RPM.... shift to 2nd at 45 MPH, shift to 3rd at 67 MPH, shift to 4th at 92 MPH, shift to 5th at 120 MPH. Did that allow you to get past 90 MPH? A healthy LT1 with stock gears and a T56 should top out at about 155 MPH in 5th gear, assuming your car had the previously mentioned Z-rated tire option.
Old Jun 24, 2013 | 03:01 PM
KW Baraka's Avatar
Re: 95 speed
Yes. IF the PCM has been reprogramed to top out at 90mph, then have the PCM recalibrated to remove any speed limiters and have it set to rev-limit at 6000+ RPMs.
Also.....do what Injuneer suggested......get to a relatively secluded spot (maybe the same track?) and rev to approximately 5500+ RPMs in 4th and 5th gears to see what that does for getting past the 90mph mark.
If you hit that 90mph wall in BOTH those gears, I'd look into having the PCM checked for a speed limiter.
KW
Old Jun 25, 2013 | 02:03 PM
Re: 95 speed
I received this PM from vhtony:
It just won't go higher than 90 mph, i get it up to 90 and my car refuses to go any higher
You have to answer the questions. There is no way anyone can help you with the limited info in that sentence.
Were you trying in 6th gear?
Did you try exceeding 90MPH in the sequence of gear shifts I suggested?
How does it "refuse".....
-engine shuts down like it hit a rev limiter or a speed limiter?
-engine loses power, like it is misfiring or running out of fuel?
Old Jun 25, 2013 | 03:56 PM
vhtony's Avatar
Re: 95 speed
I hit 90 mph and I'm in 5th usually, then the rpm's will not go any higher than 3500 so i though hmm, maybe try shifting to 6th and push the gas, that didn't help either rpm's still under 2000 and they wont go higher, but in any other gear i can get them up above 3500 easy
Old Jun 28, 2013 | 02:12 PM
vhtony's Avatar
Re: 95 speed
I think i may of caught the problem, i took it to my dad's mechanic and it turns out i need a new clutch and work on my transmission because they both are shot right now
Old Jun 28, 2013 | 06:46 PM
MDZ28's Avatar
Re: 95 speed
my speedometer is the lower of the two you have stated, but I have buried the needle and kept going faster.
did all cars with the 120mph speedo come with this speed limiter?
the only reason I ask is because Im curious if my pcm has already been tuned.
