95 shift kit
Old Jan 18, 2004 | 02:43 PM
jeffwood's Avatar
95 shift kit
does anyone have pictures of the wiring for the 'free' shift kit in the 95 z28? im thinking about mounting the button in front of the console behind the shifter.
Old Jan 18, 2004 | 02:52 PM
Performance shift info.
rough diagram
Old Jan 18, 2004 | 03:23 PM
jeffwood's Avatar
thanks
Old Jan 18, 2004 | 03:25 PM
jeffwood's Avatar
im wondering if i can just use a simple on/off metal toggle switch and drill a spot on my console to mount it... without using my asr light.
Old Jan 18, 2004 | 03:27 PM
Please read the instructions. You must use a momentary contact switch. Touch the switch once, it toggles performance mode on. Touch it again, it toggles it off.
Old Jan 18, 2004 | 03:30 PM
jeffwood's Avatar
'momentary switch'? does that mean it is only active when i have my finger down on it.? and is perfomance mode anything id want to use in daily driving situations to give better shifts?.. or will it increase transmission pressure and cause premature transmission failure?
Old Jan 18, 2004 | 03:31 PM
jeffwood's Avatar
ok.. sorry.. you posted that response before i saw it.. was typing out previous post
Old Jan 18, 2004 | 03:34 PM
You can probably find a ton of info with a search for "performance mode".
The switch provides a momentary ground to the pcm to turn the mode on. You don't hold the switch down. It's like your TV- when it is off, you push the button to turn it on. When it is on, you push the same button to turn it off.
You are utilizing factory programming already in your pcm. It won't hurt your tranny.
Old Jan 18, 2004 | 04:00 PM
FastZinTennessee's Avatar
I tried this, and noticed no noticeable improvement. Some people say the shifts feel a little firmer afterwords. But hey it's pretty much free so what the heck!
Old Jan 18, 2004 | 04:15 PM
The biggest change is in shift timing. It is not meant to be a replacement for a shift kit, though it does add a little shift firmness depending on conditions.
QuickSilver02
Apr 7, 2015 11:12 AM
armedtrigger
Feb 24, 2015 08:30 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
RedLineRev
Jan 23, 2003 03:51 PM
TrouserSnake
Aug 7, 2002 12:43 PM
