95 shift kit
Originally posted by jeffwood
im wondering if i can just use a simple on/off metal toggle switch and drill a spot on my console to mount it... without using my asr light.
'momentary switch'? does that mean it is only active when i have my finger down on it.? and is perfomance mode anything id want to use in daily driving situations to give better shifts?.. or will it increase transmission pressure and cause premature transmission failure?
You can probably find a ton of info with a search for "performance mode".
The switch provides a momentary ground to the pcm to turn the mode on. You don't hold the switch down. It's like your TV- when it is off, you push the button to turn it on. When it is on, you push the same button to turn it off.
You are utilizing factory programming already in your pcm. It won't hurt your tranny.
Originally posted by FastZinTennessee
I tried this, and noticed no noticeable improvement. Some people say the shifts feel a little firmer afterwords. But hey it's pretty much free so what the heck!
armedtrigger
Feb 24, 2015 08:30 PM
