95 pos z28 won't start
Old Apr 14, 2009 | 08:44 PM
Camaroz28lt1383's Avatar
Well we have a 95 z that won't start still, new plus wires opti coil, I gets spark and fuel. I've read a lot of post on here about all of these same symptoms, if you spray starting fluid in the intake it shoots a flame out, so I'm assuming the timings way off or something like that, any ideas? Thanks, Paul
Old Apr 14, 2009 | 08:52 PM
silentsprintero's Avatar
Any mods, condition and mileage on your car, A4 or M6? Are you getting spark at the coil wire or at each spark plug? There are 3 ways for the opti to fit on a '95+, are you 110% positive you have it indexed correctly?
What's your fuel pressure with the vacuum line disconnected and does it hold pressure after turned off. Also check for fluid under the vacuum line to the FPR.
I just went through the exact thing with my '93, repaced the coil, wires, plugs, opti cap and rotor and it still wouldn't start. Today I picked up an ICM from GM and it started without hesitation, better than it ever had before. $207.XX after tax but well worth it I needed my car back.
Old Apr 14, 2009 | 09:02 PM
Maverick_997's Avatar
re-check plug wires had two mixed up and it would spit flames
Old Apr 14, 2009 | 10:31 PM
I completely forgot to add we put a 93 engine in it, so it has the old style opti. It is completely stock, it is getting spark at the coil and the first two plus on the drivers side forsure. Checked the timing chain and every thing looks good, no excessive slack or anything.
Old Apr 14, 2009 | 10:47 PM
Shooting flames out the intake most often indicates improper spark timing. Check plug wire routing and proper indexing of the opti.
Old Apr 21, 2009 | 11:29 PM
Well more on this car, pulled the timing cover, timing chain in within spec. Put the opti back on and new plugs and ICM, now no start still. It is now throwing a Code 42 saying IGN SYS grounded? Im not real sure what this means exactly. Anyone else have this code and a solution on what it means. Thanks for your help, Paul.
Old Apr 22, 2009 | 07:06 AM
42 means the computer is not sensing that the ICM is working. Could be the wire from the computer to the ICM is grounded, shorted or not making connection or the ICM or computer is bad. Do you get 1-4v AC on the white wire (ICM connector cavity B) when cranking?
mr28
Apr 20, 2016 05:44 PM
Jessie4tin
Jan 7, 2015 08:53 AM
Dyoung_Z28
Nov 25, 2014 05:26 PM
mr28
Nov 23, 2014 11:11 AM
Brent94Z
Mar 21, 2002 04:44 PM
