95+ Opti SHAFT question ( not the dowel)
Old Jul 23, 2005 | 04:50 PM
BLUETOPTA's Avatar
I want to use a 95+ Opti on a 94 camshaft. I HAVE THE CORRECT DOWEL FOR THIS. BUT the opti center shaft is too long. Is it possible to cut down the opti shaft that has the o rings on it?
Old Jul 23, 2005 | 04:59 PM
Crazy95Z's Avatar
Re: 95+ Opti SHAFT question ( not the dowel)
I believe you will have to swap timing covers.
Old Jul 23, 2005 | 06:28 PM
The shaft is too long because the hole in the front of the pre 1995 cam is too short. You have to swap cams to use the vented opti. That's an essential step in swapping to a vented opti.
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
importkiller94
Jan 17, 2015 09:03 PM
Injuneer
Dec 15, 2014 09:36 AM
