'95 LT1 - can't keep valve lash set correctly
Old Nov 6, 2021 | 09:07 AM
RealDealZ28's Avatar
I'm working on my '95 LT1 Camaro. I rebuilt the engine 6 months ago and installed a CC306 cam and Comp's beehive springs (cam part number from Summit is CCA-07-306-8 and the springs are CCA-26918-16). I kept the stock heads for now and planned to upgrade later. I also kept the original head studs and went with OEM style rocker arms and nuts. I've had a constant problem with the rocker arm nuts backing off and messing up the valve lash. I'm having to pull the valve covers every 3-4 weeks to adjust the valves again so that they won't rattle. Is this because the stock head studs and nuts aren't meant to hold the additional pressure from the Comp Cams springs? If so, what head studs, rocker arms, and nuts should I go with? I still have the stock valve covers. I appreciate any help!
Old Nov 6, 2021 | 01:22 PM
Chimera96's Avatar
Re: '95 LT1 - can't keep valve lash set correctly
I assume you have aluminum heads??
if iron head than those studs are press in and those can "lift" with aftermarket cam & springs
Been over 20 years since I had stock rockers/nuts so IDK if they are "lock" type nuts. If so maybe they have been used to much and just not holding. On Ford motor (302) I would "double nut" the stamped rocker but I doubt there is enough rocker stud length
I would just buy some ARP 7/16 RR studs and some Comp ultra pro mags RR. You will need to trim the drip baffles on stock valve covers but they otherwise fit fine and trimming is just a 5 min job of the VC
trim intake manifold side
Old Nov 6, 2021 | 05:38 PM
Right, it has aluminum heads. Here's what I'm thinking:
ARP 134-7103 rocker studs
Comp 17005-16 or Comp 1826-8 roller rocker arms
Trick Flow TFS-300400623-8 guideplates
Do I need hardened pushrods too?
luckyou03
Feb 26, 2006 08:26 AM
Heatmaker
Nov 17, 2003 01:02 AM
Ken Cemo
Jun 22, 2003 09:48 PM
Rico
May 21, 2003 07:08 AM
n2ceptor
3rd Gen / L98 Engine Tech
Oct 31, 2002 06:38 PM
