95 LT1 accelerator cable differences
Old Jun 12, 2013 | 07:00 AM
4586's Avatar
Going to install a 95 LT1 engine/auto in a street rod...the throttle body cable is broke. Went online to buy another and they show cables for traction and non traction control?
What's the difference between the cables?
Probably will need to shorten it anyway.
Ed
Old Jun 12, 2013 | 07:34 AM
Re: 95 LT1 accelerator cable differences
With TCS the throttle cable is in two parts. One from the pedal to the TCS servo and another from the servo to the TB. If you don't have TCS, you won't want that cable (can't see you wanting that on a rod, anyway ). Non-TCS cable goes from the pedal to the TB (as any normal cable).
Old Jun 12, 2013 | 08:07 AM
4586's Avatar
Thanks Shoebox
The cable on it was connected from the throttle body to the pedal..so I need a non traction control cable (to cut up)
Old Jun 12, 2013 | 11:10 AM
I am not exactly sure what the end of the TCS pedal to servo cable has on it (whether it is the same as what is on the TB end). It would likely be shorter, if that is what you are after. If you could find one to look at, it might fit your needs.
Parts Wanted
Mar 17, 2015 11:24 PM
edman
Jan 25, 2015 02:41 PM
InfernalVortex
Jan 17, 2015 09:35 AM
Sarahrope64
Nov 27, 2014 11:17 AM
Jul 4, 2005 05:00 PM
