95 Coolant Fans Problem/Setup
Old Jun 6, 2010 | 09:37 AM
FastandBlue's Avatar
So, as Injuneer just told me, they switched over from 1 fan low / 2nd fan high temperature setup to a dual low/hi setup for both fans. Well that's a bit interesting because on my 95, one of my fans doesn't work, and the other one only comes on at temps above 240. Wouldn't both stop working? And why the hell does it only kick on after 230-240 degrees. This is very curious indeed. Now I'm starting to wonder about the ECT, the PCM, etc etc etc. Injuneer told me it was the 94 that started switching over, so that leads to some interesting implications with my fan problems.
Old Jun 6, 2010 | 10:00 AM
CstIrnFst's Avatar
It sounds like one of your fans just isn't functioning correctly. The fans in your car are run in series, so if one fan gets power, the other one does as well. The only reason I can think of for one of your fans working and the other not is that a fan needs replacing. Have you tested the nonfunctioning fan to see if it's any good?
Also your fans should come on low at 226 degrees, not 240. High speed is at 235.
Old Jun 6, 2010 | 10:19 AM
Yeah, so high speed works on one fan, but that same fan DOESN'T have low speed. And then the other fan just doesn't work at all. I'm going to test the bad fan later this week to see if the motor is bad.
Old Jun 6, 2010 | 10:21 AM
95s have low/high speed fans - not primary/secondary.
http://shbox.com/1/4th_gen_tech2.html#cooling
Old Jun 6, 2010 | 10:25 AM
Lol, yes, we just established that. We're trying to figure out why I only have high on one fan, and nothing on the other.
Old Jun 6, 2010 | 10:30 AM
Study the info and schematics and troubleshoot. That's why I posted the link. If the low speed relay circuit is not working you would only get high speed on the right fan.
Old Jun 6, 2010 | 10:32 AM
Alright, will do... Damm, this car feels like a never ending headache sometimes.
Old Jun 6, 2010 | 10:50 AM
Once you understand how the fans work, you will realize they are not that complicated.
blac94Z
Feb 15, 2021 09:43 PM
Magenta_Hearts
Mar 29, 2017 08:54 PM
Biggiebound
Apr 23, 2015 08:50 AM
MattFick
Feb 15, 2015 10:16 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
