95 Camaro z28 wont start
Old Jan 24, 2008 | 03:34 PM
RyanMcTit's Avatar
My buddy has a 95 camaro z28 and it wont start. We checked the battery and everything checks out fine. But when we put the key in none of the gauges light up on the dash. The beeping sound comes on and the windows go up and down. But when you try to turn the key nothing happens.
Any help will be appreciated! Thanx
Old Jan 24, 2008 | 10:22 PM
RyanMcTit's Avatar
anyone?
Old Jan 25, 2008 | 06:39 PM
billymz28's Avatar
check all grounds. and cables then maybe the ignition switch
Old Jan 25, 2008 | 06:53 PM
JooneJune's Avatar
Does it have an alarm system installed? poss. with a remote start?
post up more information...
Old Jan 25, 2008 | 08:55 PM
95camarodude's Avatar
check your cabes on your starter and make sure its wired right. i made the mistake of putting the ground wire on the prong on the starter and it wouldnt turn over. I drilled a whole in the body on the undercarige of the car put the ground there and it fired right up.
Old Jan 25, 2008 | 08:57 PM
it almost sounds like a dead baterry though. or a blown fuse. check under the hood in the fuse box. its a red fuse with a 10 on it i believe dont quote me though.
CamaroHeed
Mar 18, 2020 09:50 PM
fpete1992
Dec 11, 2014 03:51 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
grendal
Apr 15, 2010 05:20 PM
2000silverz28
Jul 20, 2002 06:14 AM
