95-97 timing cover
Old Feb 2, 2005 | 08:09 AM
hawk232's Avatar
95-97 timing cover
is a 95 timing cover interchangeable with a 96/97? i saw a page linked with the differences of the different years, but it was unclear if a 95 could be used on a 96-97 car and visa versa
Old Feb 2, 2005 | 08:31 AM
Re: 95-97 timing cover
The 1995 cover has no provision for the crank position sensor that the 1996-97s do.
Old Feb 2, 2005 | 08:33 AM
hawk232's Avatar
ok, well i have a 94 and will be "upgrading" to the vented, are the opti's different in 95 from 96/97? if i get a 95 opti, would i be able to use a 97 cover?
thanks
david
Old Feb 2, 2005 | 08:46 AM
lillbush5555's Avatar
thanks
david
You COULD but you will need to fill the whole where the CPS goes (might be tricky) your best bet is to find a 95 timing cover or like I said find a way to fill the hole in the 96-97 cover
Matt
Old Feb 2, 2005 | 08:49 AM
ibanez6rg's Avatar
95+ optis are all the same.
Old Feb 2, 2005 | 09:09 AM
anaik's Avatar
Don't know if you're aware, but the cam will have to be modified or changed for the switch over.
http://para.noid.org/~muttvette/opti.html
Old Feb 2, 2005 | 09:48 AM
96m6lt1's Avatar
Anaik thank you greatly for posting this link,i am about to instal my 95 motor into my 96 and seeing the difference with the timing cover,i am sure that you saved me time due to the change and since both motors will be out of there homes it will be easier to swap them,thanks
Old Feb 2, 2005 | 11:50 AM
hawk232's Avatar
yes, i am aware that the cam will have to be swapped but thanks for posting the info
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
*Emilia*
May 13, 2015 09:05 AM
willismoons
Feb 14, 2015 08:42 PM
Queens94z28
Dec 20, 2014 09:11 PM
