94z28 Hypertech Power Programmer III????
Old Aug 22, 2015 | 11:35 AM
colts0455's Avatar
ok ive heard that hand tunners are a wast of money. however what does the Hypertech Power Programmer III do whats it power tune do ? i tried read on it couldn't get much. i do like how can set fans i don't like factory set up to me fans cut on to high any way cheaper to fix that? also heard about mail order tune but id like to get that done when im done with my mods.
Old Aug 22, 2015 | 02:56 PM
Re: 94z28 Hypertech Power Programmer III????
The Hypertech inserts a "performance" program of their own design that is generally based on a stock engine (or one with a 160 degree thermostat). There is no customization of the program for other engine modifications, so it is generally considered a waste of time if you have engine mods. It does let you change fan temps and some shift parameters for an automatic, but is very limited, extremely low bang for the buck and sometimes a step backward in performance.
There are programs you can use with a laptop/PC and cable that are much better. Read up in the computer/diagnostics forum.
Old Aug 22, 2015 | 03:31 PM
colts0455's Avatar
thxs shoebox i just did this
i replaced it with 8mm spark plug boot the stock one rubber was all cracked on it. the part that goes on the tb fir fine but the end that the line goes into feels lil loose. is this ok i took her out for a drive and seemed fine ? how can i tell if shes not running right.
Old Aug 22, 2015 | 05:03 PM
You can easily test the integrity of the hose section with a vacuum tester or just use your lungs.
Old Aug 22, 2015 | 06:07 PM
colts0455's Avatar
what do you mean ? what im saying is i replaced that evap line just like one in the video with sp boot the end that goes to tb fit good but end that the back line goes into feels lil loose is this ok ? how will i tell if somethings wrong.
Old Aug 22, 2015 | 06:56 PM
TGGodfrey's Avatar
its not ok to be loose. If its real close you can use a zip tie as a clamp to seal it up. Otherwise find another solution.
Old Aug 22, 2015 | 07:57 PM
colts0455's Avatar
they dont make that part anymore why they say use sp boot the tb part fits good the other fits so so i can pull it off easy ? i can try the zip. if it a lil loose what will it do ?
Old Aug 22, 2015 | 08:00 PM
colts0455's Avatar
i used the 8mm think i should do 7mm ?
Old Aug 22, 2015 | 08:03 PM
Use RTV at the loose connection. Make sure the RTV is "sensor safe".
Old Aug 22, 2015 | 08:11 PM
colts0455's Avatar
rtv do they sell it at local parts store ? also whats a good Serpentine Belt mine looks new but sequels soooooooooooooo bad.
Old Aug 22, 2015 | 09:47 PM
Put whatever laps of electrical or teflon tape needed on the EVAP solenoid port to snug it up. Removing the end at the TB and blowing into it should tell you if it is leaking. The ports should be closed from each other unless energized.
Goodyear Gatorback is a good belt.
Old Aug 22, 2015 | 11:37 PM
I think the part that is loose is the way the plastic tube fits into the small (wire) end of the spark plug boot.
Yes, any auto parts store will stock various grade of RTV sealer. Ask for it.
Old Aug 23, 2015 | 10:58 AM
colts0455's Avatar
can you send a ebay link to the Goodyear Gatorback belt that will fit my 94 z28 cant find it.
Old Aug 23, 2015 | 11:49 AM
Because of a change in the size of the a/c pulley during the 1994 model year, you could have one of two different sizes of belt. One ends in 637 (shorter), the other in 642 (longer). I know Summit has the 4060642, but you may need to measure your old belt to be sure of the size. Sorry, I am not going to search the whole internet when you can do it.
Old Aug 23, 2015 | 11:57 AM
colts0455's Avatar
ok you gave me info about the belt so i thought you had a link was all i found this one says will fit my 94 z28 http://www.ebay.com/itm/231575990038?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
