94Z wont start issue
Old Jul 30, 2012 | 09:08 AM
  #16
mrmint69's Avatar
Re: 94Z wont start issue
A fully charged battery is important. Get it charged and maybe tested. Most auto parts stores will charge and test for free.
Old Jul 30, 2012 | 11:36 AM
  #17
Originally Posted by tgarrisoniv
STILL havent got this thing to start. i think its a bad opti. still blowing air out when it should be sucking. could it be 180 out?? been out of town for a week, im going to pull cover and check timing today. you guys said it can only go in one way but it would just make me feel better and eliminate that possiblity. i dont know what else it could be. 42lb fuel pressure. spark looks good. obviously has compression and it still wont start. it will try and try and try until it kills the battery which will now barely hold a charge guess need new one of those too.
It is supposed to go in only one way. Many people have managed to force it on in the wrong postion.
Old Jul 30, 2012 | 12:37 PM
  #18
Who here ever told you that? Please be specific, because virtually anyone who has been on this site more than a couple of years knows that IN THEORY it will only fit one way, but a surprisingly large number of people have managed to assemble it incorrectly.
Old Jul 30, 2012 | 03:15 PM
  #19
mrmint69's Avatar
I think it can only go on one way, unless you force it on. It should go in very smooth with no pressure needed.
Old Jul 30, 2012 | 03:27 PM
  #20
Camaro350z28's Avatar
you can definitely put it on the wrong way.however if you notice the bolts that hold the opti to the motor at those points it does not sit flush.
Old Jul 31, 2012 | 07:09 AM
  #21
tgarrisoniv's Avatar
FINALLY got it running! why doesnt the harmonic balancer have a mark for top dead center?? i thought that possibly the arrow on it was for top dead. not true. i was dead set on this being a timing/ignition problem. fuel spark not in agreement so i simply pulled no 1 plug, let it blow my finger out, took opti out and grinded out the odd tooth and pushed it in pointing to the lead for no 1 plug. after getting this pretty damn close, put it all back together and wouldn't ya know it, firing right up! (actually i even forgot to put no 1 back in and was wondering why it was running rough LOL!! but but everything back together, and shes purring like a champ. This is my girlfriends car and my first experience working with an Opti. in my opinion, it is a horrible idea. i dont like them at all. how stupid is it that in order to properly set timing you have to do all this, take the whole front end of the motor apart, just to set timing?? makes no sense to me but its running fine now so hopefully wont have to do take it apart for awhile. thanks for the help guys.
Old Jul 31, 2012 | 08:33 AM
  #22
The pulley does have a TDC mark. However the hub is not keyed and if someone was there before you and did not orient it like it came from the factory, the mark could be off.
So, you ground off the tooth on the splined drive that properly indexes the opti? Why would you do this? Honestly, it sounds like the source of your complaints and errors from the whole experience is from your lack of knowledge and research of what you were doing. It is a relatively simple procedure that does not even require you knowing where TDC is.
Old Jul 31, 2012 | 03:39 PM
  #23
Guest47904's Avatar
Guest
Why didn't you try aligning the #1 contact BEFORE you ground off the indexing tooth???????
Old Jul 31, 2012 | 10:58 PM
  #24
mrmint69's Avatar
Glad its running good and you learned a few things!
Old Jul 31, 2012 | 11:56 PM
  #25
You need to pay more attention to the posts you read on this site. I'd estimate at least 10% of the Opti installs end up with the splined shaft indexed incorrectly. People will swear they aligned it properly, only to find out, after several people have told them to check the alignment, and only reluctantly checking, that they assembled it wrong.
So simple.... even a cave man can do it (incorrectly).
Old Aug 1, 2012 | 01:40 PM
  #26
mrmint69's Avatar
I was only stating, that if it took any amount of work of pressure to get it on, you probably did it wrong. Everyone has a different idea, what going on easy means. I marked the opti and direction when removed and made extra care to be sure the new opti went the exact same way. Most probably pop that thing off and worry about it later, when it might be to late to use as a guide.
Old Aug 1, 2012 | 02:52 PM
  #27
jpaugh's Avatar
What opti does reveryone recommend these days? Aftermarket or GM and where is the best place to get one? I believe my opti is causing my problems - https://www.camaroz28.com/forums/lt1...-start-867869/
Old Aug 1, 2012 | 10:25 PM
  #28
mrmint69's Avatar
Oem ac delco
kksi
Feb 16, 2015 06:49 PM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
Alex Barnes
Jan 24, 2015 10:21 PM
David Dorris
Jan 17, 2015 08:10 PM
