94z obd connection
Old Jun 28, 2003 | 03:16 PM
jammer's Avatar
Angry 94z obd connection
My 1994 z28 wont spit out any codes when I hook up the code reader (OBD I). I have heard that some 94s have to be checked with an OBD II reader eventhough it is supposed to be an OBD I. I know I've got something wrong because the SES light comes on after warmed up and that kicks on both electric fans and prevents the A/C compressor from working. Runs bad too. HELP!!!
Old Jun 28, 2003 | 03:57 PM
slopokrodrigez's Avatar
What scanner are you using?
Try the bozos at Autozone and see if they can scan it.
Try an independant garage, if they use the snap-on scanner like I do it's no problem. I own a 94 and works like a dream.
Old Jun 28, 2003 | 04:04 PM
sabre81's Avatar
The cheap scanners with the 3 pins (like at autozone or any other auto parts stores) will not work. The cheapest way to scan your codes is to use a laptop, freescan and a data cable from akmcables.com. Or you can go to a mechanic and have them do it. My local mechanics wanted 100 bucks to hook it to their code reader.
Old Jun 28, 2003 | 06:41 PM
jammer's Avatar
The cheapo scanner (about $30) I have is an INNOVA 3123.
What software and cables would I need to hook up to my laptop?
Old Jun 28, 2003 | 06:44 PM
jammer's Avatar
Autozone in California no longer reads codes for the general public because too many complaints it was stealing thier business. I called 4 Autozones in NOR_CAL and got the same story at each place.
Old Jun 28, 2003 | 07:01 PM
badass383's Avatar
Screw Autozone, go to a local garage and get the codes. Check out the scanners at PEP Boys. If they don't work take them back but 94's are all obd and it's easy to get a scanner for them.
Keep the faith
Old Jun 30, 2003 | 05:52 AM
sabre81's Avatar
you would need / freescan from http://www.andywhittaker.com/ecu/ecu_software.htm&e=912
And then choose your cable from http://www.akmcables.com/ic.htm according to your cable and how much you want to spend(unmolded less durable cable are cheaper).
Nayr
Mar 3, 2023 08:34 PM
Novo
Jun 14, 2016 02:58 AM
Jeff1904
Jun 5, 2016 05:00 PM
drt
Sep 27, 2015 04:39 PM
jackpawt883
Sep 10, 2015 08:53 PM
