94LT1 into 93TA.... help
Old Sep 12, 2005 | 11:00 AM
Todds355TAGT's Avatar
I know of a few little differences between the 93 and 94 LT1,
my concern is the MAF to speed density system.
anyone done this before?
can the 94 be put in the 93 TA
ToDDR
Old Sep 12, 2005 | 11:56 AM
Z95m6's Avatar
Re: 94LT1 into 93TA.... help
Just put your 93 intake on the 94 and go.
Old Sep 12, 2005 | 07:19 PM
TTT
thanks for the input,\
but I dont think the 93 injectors will supply enough fuel for the 355
430hp
i want to use my computer on the 93 cause it has the ed wright tuning!
ToDDR
Old Sep 12, 2005 | 09:29 PM
Z95m6's Avatar
Originally Posted by Todds355TAGT
TTT
430hp
ToDDR
I'm not to sure the 94's will be able to support your hp level either. You are gonna run into problems if you run your 93 ecm setup for 22lb injectors with the 24lb injectors off the 94. Now that i think about it you might be able to run the 94 intake with 94 rails and your 93 ecm.
Old Sep 12, 2005 | 09:37 PM
1racerdude's Avatar
Every thing will work with the SD if ya get a tune. Leave it SD and just remove the mass air.
Old Sep 13, 2005 | 12:08 AM
madwolf's Avatar
94 LT1 into 93 car.
You will need to swap your 93 o2 sensors into the 94 manifolds, unless you will be using the 93 manifolds/headers.
The IAC valve under the TB has a different connector. You can swap the bottom plates on the TBs, or swap the whole TB if you're too lazy. Or even swap the connectors on the harness side. All three options will work.
Everything else will hook up and work fine. The fuel lines will need some rerouting, but they will work. You can also get some new 94 ones if you want. They're only like $16 or so.
For 430 RWHP you need some 30# or 36# SVOs or Racetronix injectors. Don't wait to find out the expensive way.
Old Sep 13, 2005 | 08:12 AM
Max 93's Avatar
ToDDR
I converted my 93 to a 94 style PCM so yes it can be done
FSTFBDY
Jun 23, 2009 08:23 PM
SNAKE_EATER
Parts Wanted
Jun 19, 2007 06:34 PM
pgriffith
Jun 19, 2003 02:47 AM
Farfrominnocent
Jun 16, 2003 11:50 AM
