glasspaks on an LT1..?
ok ive decided to put off the heaaders for a little while so i definately need somethin to change the tone of my exhuast till then (bullets on manifolds sounds like a harley at part throttle
) but im thinkin about getting thrush or cherry bomb glass paks.. anyone ever heard glasspaks on an LT1 or have a sound clip? and how much should one of these cost.. advanced just told me 45 each for the 2 1/2 in/out with 24in case... arent these things usually like 20 bucks each!?
Re: glasspaks on an LT1..?
They sound fine if you like the old school V8 sound.
I run Hooker LTs and true duals with Purple horny header mufflers with turndowns. I had to shorten them a bit to clear my DDs and I had O2 bungs welded in. I love the way they sound.
Ive heard this term a lot and never knew what they were but I knowthey are cheap and make your car much louder. What exaclty is a glasspack?
My Guess: A replacment for a Cat which is cheap and containts glass. lol
if not.. then its a straight through pipe with a shell around it... holes in the inside wall between the shell and inside wall is usually fiberglass of some kind and the glass walls i mentioend before in the center
right now i have bullets.. only reason im changing is because i want a "tone" before until i can get the money for headers.. again.. but my main question is how much quieter will it be? and as far as breaking the glass inside.. itld be pointless to do ALL the glass cause thats what i have right now
but what about only breaking a cpl of the walls in each muffler (old fashioned way with a water hose of course
) my dad had a 4.0 jeep like that once and it sounded awesome
anyway... anyone know how the loudness compares glasspack vs bullet ? i know itll be somewhat quieter.. and ill once in awhile miss the echo but i dont want a harley sounding car at part throttle
(cursed manifolds~!!~)
Glass walls.......??
A glasspack muffler is a round muffler that is a straight through design, the pipe is perforated inside and fiberglass packing surrounds this perforated tube inside the muffler. As time goes by and you drive the car this fiberglass packing burns out and its muffling capabilities are diminished.
You either love em or hate em.
As for how loud they are, I get lots of comments on how quiet my car is (this is relative, my car is still loud) for such a short exhaust, but it SCREAMS at WOT.
The glasspacks are going to be even more raspier then the bullet mufflers, and probably louder.
Have you actually had anyone take your car around the block and let you hear it? If not you should, it sounds totally different. I would keep the bullets.
Only reason why I ditched my bullet mufflers were cause I wanted even more of old school sound. So I went with these. http://www.sweet-thunder.com
i think one reason mine seems to be raspier is because of a slight miscommunication when i was getting the exhuast done.. the bullets are 3in. in/out while the exhuast pipe is 2.5in. would that make it raspier? in other words would i be better off to change to teh correct bullet.. or go ahead with the glass packs.. and from that website it makes it look like a glasspack and a bullet are basically the same? now im just confused =/
and yeah i had someone drive it around the block for me once... but that is different this car sounds different everytime i drive it *shrug* one day itll be nothin but grumbles and the next its all echoes.. most of the time its a mix guess its my foot.. but i cant stand being beside a wall, pressing the gas, and hear the echoes... maybe i can get the shop to rig up a way to let me hear the glass packs before they do any actual "labor"
Bullet mufflers aren't that much different except they are a tad bit quiter and they flow better and will last longer.
Also, are yours true duals? And did you have them fab up a new y-pipe for you? I know that sometimes if they there is bend in the pipe that has a large kink in it, it can add more of a rasp to it. Thats why I went with individual mandral bends for all my stuff.
Both my buddys L98 and my formy have headers and dynomax bullets at one point. And neither were as raspy as a loudmouth or borla. But then again ours were tuned pretty decently. And if the car is running rich it will run really raspy, thats a fact. How old are your front o2 sensors?
Mike
Mike
front o2's as far as i know are as old as the car =/ .. oh and yes its true duals with the stock y-pipe chopped before it combines into 1.. also while were trying to find the source of this "rasp" think that difference in muffler vs. pipe size might be another cuase?
I'm willing to bet that the problem with your rasp is your old o2 sensors. They are probably causing the car to run a little on the rich size, which can cause more of a raspy tone on a exhaust setup with no cats.
I don't thinky your problem is that your going from a 2 1/2 to a 3 inch, since I have seen people run larger tail pipes and not run into this problem.
The Dynomax bullets are just a short glass pack. They are the same thing. I had the bullets on my Caddy (LT1/T56) with cats and 2.5" dual pipes. I had turn downs rights off the bullets before the rear axle. Sounded AWESOME. BUT... as soon as you add pipe behind them, they get raspy. I had to add tail pipes to pass inspection and they got raspy up top and I didn't like them any more.
If it's the raspiness you don't like, try moving the bullets further back in the exhaust as close to the end as you can (not exactly easy). Maybe try some resonator tips? That may cut the raspiness out of the system.
If you're just looking for cheap, sorta quiet... The Summit Turbos sound great and are only $14.75 each. They are significantly quieter than the bullets though. No raspiness at all.
Might you consider a Spin-tek muffler? They're just as loud (if not louder) than glass packs and bullets, but not quite as raspy.
I've heard good things about Magnaflow, too.
That's my $.02. YMMV.
