94 z28 water pump & opti ? help :/
Old Sep 25, 2015 | 05:39 PM
colts0455's Avatar
ok well my cars locked out till get new key my vats will not let me into my car. my water pump is starting to show signs of leaking so its getting changed my ? is do i need to do the opti while im doing the water pump & also do i need to replace Water Pump drive shaft seal ? & optispark seal ? or will they be fine. just feel like cant get ahead on this car :/
Old Sep 25, 2015 | 08:53 PM
Re: 94 z28 water pump & opti ? help :/
It depends on whether you are having issues with those things.
Old Sep 25, 2015 | 09:36 PM
colts0455's Avatar
ill shoot & say opti is fine even tho im sure is from 94 & no idea about seals but i do know the water pump is leaking.
Old Sep 26, 2015 | 10:12 PM
colts0455's Avatar
so how can i tell if seals need to be done ? its got 146miles pretty sure water pump is stock & opti & seals
Old Sep 27, 2015 | 11:31 AM
You simply look for evidence of any leaks.
Old Sep 27, 2015 | 01:07 PM
colts0455's Avatar
ok i think im just doing the pump weather just been so bad here in NC. gotta wait on my key my vats locks me out cant crank my car :/
HectorM52
Jul 30, 2017 11:46 AM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
pologreen97z
Dec 2, 2014 10:42 AM
thenewkid
Nov 27, 2014 09:41 AM
