'94 Z28 Stalls!
Old 08-27-2015, 09:25 AM
  #16
Re: '94 Z28 Stalls!
The oil pressure sensor does not connect to the PCM, nor is it interlocked with the fuel system in any way. Can't be the problem. Corvette LT1 is a different story.
Injuneer is offline
Old 08-27-2015, 12:42 PM
  #17
jbert55's Avatar
Re: '94 Z28 Stalls!
OK, thanks!
jbert55 is offline
Old 09-10-2015, 06:02 PM
  #18
jbert55's Avatar
Re: '94 Z28 Stalls!
So my mechanic friend was able to find his OBD1 tester, and he is getting a code 16. Kind of surprising seems as I have a MSD Optispark on here that is less than a year old....Guess even the good ones go bad??
jbert55 is offline
Old 09-10-2015, 09:48 PM
  #19
Re: '94 Z28 Stalls!
Based on postings over the last 10 years or so, on three different sites like this where I am (or was until recently) active!, I would estimate that the MSD is no better than, and possibly worse than the AC Delco/Delphi units with regard to failure rate. I've reviewed data logs that identified two MSD units that failed, producing strange erratic high resolution signals, one of them immediately after being rebuilt by MSD and returned to the owner.
Any unit can fail... even the factory parts. None of them are bulletproof.
Injuneer is offline
Old 10-31-2015, 03:52 PM
  #20
jbert55's Avatar
Re: '94 Z28 Stalls!
Finally back! It was the MSD optispark, removed and sent back for repair. After a month I got it back and we installed it. Runs OK but still has an intermittent stumble/miss/vibration. No codes, so trying to track down anything different...
jbert55 is offline
Noenav
03-01-2019 07:38 AM
marine1bird
10
01-25-2015 12:02 AM
edxiel
01-24-2015 07:40 PM
Teal94V-6
08-31-2002 09:21 PM
Quick Reply: '94 Z28 Stalls!
