94 z28 pcm communication port wiring
Old Jan 22, 2005 | 08:07 PM
#7's Avatar
If you have a 94 maybe you can look at yours or help me with the wires to the communication port of a 94. A schematic or something would help me maybe also?
On my communication port I have 4 wires,one of the wires black/w white stripe wire(isolated by itself to one side of plug/port) is not hooked up to anything just about 10" of wire. I did not cut it its been that way since I got the car.
Can you help me determine where if anywhere this wire is supposed to go to? I am about to start messing w/ tunercat and datamaster so I need to make sure this port in in order correct?
T.
Old Jan 22, 2005 | 09:07 PM
madwolf's Avatar
Re: 94 z28 pcm communication port wiring
http://shbox.com/1/dlc1.jpg
Old Jan 22, 2005 | 10:04 PM
What cavity does the wire come from on the DLC?
Old Jan 23, 2005 | 11:47 AM
#7's Avatar
Looks like cavity G Shoebox and thanks for the tech aide madwolf.
So you know... I did check Shoebox tech first. It helps for one to know the correct name first . Somehow scanned right over that DLC. But I'm still not convinced my wire went to the keyless entry. Can you verify? The lone black/white wire on the right.
http://community.webshots.com/photo/...57612487soAFgB
Will the wire being disconnected cause problems with CORRECT connection to the pcm for data logging and programming?
some info: I have never used keyless entry or had a fob with the keys on this car.
TIA
T.
Old Jan 23, 2005 | 07:10 PM
#7's Avatar
Was buried
Old Jan 23, 2005 | 09:22 PM
I can't see how that wire can affect anything but keyless programming.
Old Jan 23, 2005 | 09:53 PM
ejfagala's Avatar
Here is a link that has the 1994 cammaro LT1 wiring diagram. It is in adobe and is in a zip file but it is free
http://home.att.net/~subzero350/
Old Apr 11, 2005 | 09:49 PM
lt1zpwr's Avatar
cool
Noenav
Mar 1, 2019 07:38 AM
Injuneer
Dec 15, 2014 09:36 AM
thenewkid
Nov 27, 2014 09:41 AM
Jul 4, 2005 05:00 PM
