94 Z28 Overheating!!!!
Old Oct 3, 2007 | 10:35 PM
texas94z's Avatar
I just bought a 94 Z28 A4 with 137,000 miles today and its overheating. On the drive home i had to pull over 3 times to let it cool down. I was pretty bummed out. When we got back me and my buddies figured out that the fans are not working. However, we pulled them and a simple connection to a battery and they worked fine. The water pump seems to be working because it takes a good mile to start overheating so there has to be some water flow. I either think its a bad sensor or connection. Also, it doesn't have a front air dam and i know thats part of the problem but it shouldn't overheat that bad. What do y'all think? Should i say screw it and make switch for the fans or what. Any help would be great.
Old Oct 3, 2007 | 11:01 PM
Zachz28's Avatar
Get a air damn, without it almost no air goes through the radiator.
Old Oct 3, 2007 | 11:38 PM
micfly83's Avatar
Definitely get an airdam on there
and then checkout that thermostat
also look under the car for any leaking coolout out of the waterpump
make sure you check the coolant level in the resovior tank and make sure its not disappearing elsewhere
Old Oct 3, 2007 | 11:46 PM
96m6lt1's Avatar
without that 25.00 air dam under the car you will overheat
Old Oct 4, 2007 | 01:58 AM
texas94z's Avatar
yeah i just bought one for 10.00. hopefully that will end the overheating.
Old Oct 4, 2007 | 07:38 AM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
If the fans aren't coming on, the coolant temp sensor in the water pump could be bad.
Old Oct 4, 2007 | 08:34 AM
Ok4thGen's Avatar
Turn the A/C On and see if the fan kicks in, if they dont theres more problems then just the sensor on the waterpump.
Old Oct 5, 2007 | 07:15 AM
95 Civic's Avatar
I had the same problem, make sure you get the air dam on first but check your fan relay. I installed a bypass switch so I could turn my fans on when I wanted to... I liked it but you cant forget to turn them on...
Old Oct 6, 2007 | 05:09 PM
Tex95Z's Avatar
The car you bought is it green?
Old Oct 7, 2007 | 01:13 AM
texas94z's Avatar
yeah its green.
Old Oct 7, 2007 | 01:18 AM
reamo04's Avatar
Get that airdamn fixed ASAP. I had a problem with mine where it would start to over-heat, and it was because my heater-core was blocked.
Old Oct 7, 2007 | 01:50 AM
Ok4thGen's Avatar
did you try turning the a/c on too see if the fans kick on?
Old Oct 7, 2007 | 10:22 AM
Tex95Z's Avatar
from Jared? I almost bought that car if it was, but you beat me to it.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Renegade Toker
Jan 23, 2015 10:27 PM
NewsBot
Jan 11, 2015 06:10 PM
Jan 5, 2015 07:14 PM
cmdeshon
Jan 4, 2015 11:15 AM
