94 Z28 Failed Emissions
Old Nov 28, 2006 | 08:15 PM
  #16
quick-z's Avatar
Why do you think that...and how do I find where it is?
Old Nov 28, 2006 | 08:30 PM
  #17
TobyZ28's Avatar
Other areas would normally be out of wack with a HC that high too. Secondly, my car was kept in awsome shape, driven a lot but kept in good shape. My Charcoal canister was toast and the same goes for the tube the goes from the tank to it.
I would guess that this will happen to most any Z thats over 10 yrs. Looking back at my previous emissions tests I saw my HC had started getting high for the last 4-5 years, i only started failing in the last 2 or 3 . Basically it got worse over time.
Old Nov 28, 2006 | 08:32 PM
  #18
quick-z's Avatar
Where is the charcoal canister located and how easy and expensive is it to replace?
Old Nov 28, 2006 | 08:50 PM
  #19
TobyZ28's Avatar
The canister itself is located in the the left rear fenderwell. Its easy to replace (tire off, remove the cover and replace canister)
However mine had a hose leak .. the hose was spongy and smelt like fuel. I had to drop the tank to get that replaced
Old Nov 28, 2006 | 08:51 PM
  #20
quick-z's Avatar
Thanks for the help. I will check it in the next few days when the snow stops! I will let you know what I find out.
Jason Short
Jan 19, 2015 06:34 PM
Firemechanic
Parts Wanted
Dec 14, 2014 10:22 AM
Queens94z28
Nov 20, 2014 06:03 PM
