94 Z28 died again. Ideas?
Old Apr 29, 2011 | 10:43 AM
bigalnyz28's Avatar
The latest problem I am having is a weird one. Car was running fine after driving about 15 minutes. Parked car and came back about 10 minutes later. Car started, went about a block, the gas gauge went all the way past full (actually into the temperature gauge), the car started bucking wildly and then died.
On attempted restart, it would barely run while constantly pumping the gas.
Went back 2 hours later, started right up and drove it home.
Parts replaced since I bought it in January: Fuel pump, opti-spark, water pump, 90% vacuum lines, TPS, IAC and ICM.
Any ideas would be appreciated.
Old Apr 29, 2011 | 03:01 PM
my1994z28's Avatar
Re: 94 Z28 died again. Ideas?
Start with the basics,fuel pressure,check spark from coil,check opti,have the ICM checked.
Old Apr 29, 2011 | 06:30 PM
bigalnyz28's Avatar
Thanks. Finally tracked it down. The ground wire on the connector inside the gas tank at the top of the sender unit had an intermittent connection.
Thanks for your help.
Old Apr 29, 2011 | 07:17 PM
GRSCamaro's Avatar
Good to hear it was a little thing this time.
Alex Barnes
Jan 24, 2015 10:21 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
A's 91 Z28
Jan 11, 2015 10:58 AM
nophix
Nov 30, 2014 10:26 PM
Ricardo
Nov 29, 2014 10:58 AM
