94 z28 diagnostic port problems
Old Apr 15, 2005 | 08:27 PM
94PurplePearlZ28's Avatar
i used a brand new actron code scanner for a 94 z28. when i plugged it in and turned on the ignition it was just like normal. check engine light came on and went off like normal and thats it.
if i use the 93 test mode and just jump the two prongs it does the same thing. is there a special few that have a a special way to diagnose the codes or something?
Old Apr 15, 2005 | 09:01 PM
mourningyou's Avatar
Re: 94 z28 diagnostic port problems
the actron scanner will not work. all it does is jump the two pins just like a piece of wire would. to scan a 94 you have to use a data cable or a power programmer.
Noenav
Mar 1, 2019 07:38 AM
oldschool
Feb 9, 2016 09:21 PM
Double aught
Parts Wanted
Nov 23, 2014 06:11 PM
Jul 4, 2005 05:00 PM
