94 z28 5.7
Old Oct 28, 2014 | 12:37 PM
steve1380's Avatar
94 z28 5.7
runs really rough has newplugs and wires and a oil change and filter still lacks alot of power and sounds like sh5t please help it has 90,000 the opti spark is org. It runs rough cold and hot. I jst did the head gasket cause it had oil in water in the oil. It's an auto starts a little tough it is stock I'm se on owner and it has no codes
Old Oct 28, 2014 | 01:17 PM
Re: 94 z28 5.7
Welcome to CamaroZ28.com!
"New Member Intro" isn't the best place to get tech help. I'll move this to "LT1 Based Engine Tech" for you.
Probably need to provide a bit more info:
-how many miles on the engine?
-manual or auto trans?
-stock or modified engine?
-if modified, what are the engine mods?
-does it start easilly?
-when does it run poorly - at cold start, when fully warmed up, both?
-do you know if the Optispark distributor has ever been replaced?
-have you scanned it for codes?
-have you checked the fuel pressure?
F'n1996Z28SS
Aug 23, 2023 11:19 PM
kennyirocz
3rd Gen / L98 Engine Tech
Feb 7, 2015 11:41 PM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
67 Camaro
Sep 14, 2002 01:00 PM
