94 Z/28...Which OBD used?
Old Jun 20, 2003 | 11:12 AM
SSkindog's Avatar
Which OBD? And what is the best way to scan for codes? Best way to read sensors dynamically? And the best way to reprogram the PCM?
Thanks in advance
Joel
Old Jun 20, 2003 | 11:14 AM
Grover's Avatar
94's were OBD I so the best way to scan and log is Datamaster. You can either use LT-1 Edit or Tunercat for programming.
Old Jun 20, 2003 | 11:20 AM
Buttercup's Avatar
OBD1
To scan and repgrogram your car you will need an appropriate interface, like what's found at http://www.akmcables.com/ic.htm You can even build your own cable if need be!
Once you have a cable you can connect to the PCM with a PC. Now you need the software.
For diagnostic abilities you can even find free software, like this http://www.andywhittaker.com/ecu/ecu_software.htm
Hands down the best diagnostic software is TTS's Datamaster however, http://www.ttspowersystems.com/software.htm which is also sold by http://www.akmcables.com/dss.htm
For reprogramming the PCM there are two major applications, Tunercat http://www.tunercat.com/tnr_desc/do_tc.html and LT1_Edit http://www.carputing.com/ At this point I think Tunercat is a better buy, but each has its own pros/cons
Hope this helps
Old Jun 20, 2003 | 11:22 AM
SSkindog's Avatar
Originally posted by Buttercup
OBD1
Hope this helps
Wow! Yes that helps, thank you very much!
Novo
Jun 14, 2016 02:58 AM
4586
Sep 6, 2015 03:10 PM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
Aug 7, 2015 08:52 AM
