94 vs 95 oil pressure sender
Old Jan 29, 2008 | 02:01 PM
Deja's Avatar
Is there any difference between a 94 and 95 Z28 oil pressure sender. The sender on my 94 engine was broken during the engine install. I had a new one from a 95 Z28, but the gauge is pegged with the engine running. I searched on several parts store websites and they seem to have different #s for these two years. So my question is will the 95 sender not work on a 94 engine? One other thing I am using a TransAm gauge cluster instead of the Z28 cluster, don't now if that matters.
Old Jan 29, 2008 | 02:06 PM
regal502's Avatar
Sounds like the multiple mis-matches of components are causing your issue.
Old Jan 29, 2008 | 03:46 PM
Try Shoebox's part number listing. It shows one sensor for the 93 and EARLY 94 cars, another for the LATE 94 to 97 cars. The difference, if I recall correctly is that the 93-EARLY 94 sensor is located above the oil filter, and the LATE94-97 sensor is located on the block behind the rear edge of the intake manifold. If both cars (94 and 95) have the same sensor location, I would think they would be interchangeable. A full deflection on the gauge typically indicates an open circuit. Check the wires.
Shoebox's parts guide:
http://shbox.com/1/Parts.htm
Old Jan 29, 2008 | 06:14 PM
Deja's Avatar
Both my engine have the sender on top behind the intake. I agree it looks like on open circuit. I did have to change the connector to use the firebird gauge cluster, maybe I crossed something. I'll ohm it all out as much as I hate to have to pull that cluster again, LOL. Thanks for the clarification on the two senders.
HectorM52
Jul 30, 2017 11:46 AM
Nickster 7
May 1, 2015 09:04 PM
KYWes
Apr 15, 2015 05:48 AM
Jessie4tin
Jan 7, 2015 08:53 AM
Jul 4, 2005 05:00 PM
