94 vs. 95 block
Old Oct 3, 2007 | 03:42 PM
11secgen's Avatar
94 vs. 95 block
i have both blocks for my rebuild.the 94 was a early 94 that didnt have the powdered metal rods.is there any benifit to either block? is there any benifit to vented or non vented opti? i sould have both,right?
Old Oct 3, 2007 | 03:44 PM
Javier97Z28's Avatar
Moderator
A 94 "block" and a 95 "block" are the same....
if you're rebuilding who cares what's inside...
Old Oct 3, 2007 | 03:49 PM
Ok4thGen's Avatar
only possibly problematic difference you would run into when putting them back together is the vented opti uses a different length pin in the end of the cam then the non vented does.
Vented optis are cheaper, and seem to last longer due to the addition of the vent line that goes to the air intake elbow.
Oh something that might be a bit different is where the oil sender unit is located on the block on the early 1994 cars the sender is located on the block above the oil pan on the drivers side, on the late 1994's and 1995's the sender is located on the back of the block below the intake.
Old Oct 3, 2007 | 04:14 PM
Jared 3870's Avatar
However the ports are there for both and one could convert it either style.
Old Oct 4, 2007 | 04:05 PM
WS Sick's Avatar
I've gone through a couple LT1 blocks and it seems like the earlier castings had thicker cylinder walls. If you have to bore I would probably go with the earlier one.
Old Oct 4, 2007 | 05:10 PM
95_MuLLeT_LT1's Avatar
Are the PM rods any better or are they worse?
Old Oct 4, 2007 | 10:54 PM
PM rods are stronger than the forged "pinks".
GREEN3112
Feb 10, 2019 09:19 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
heus
Sep 8, 2015 12:01 PM
