94 opti re-install
Old Oct 16, 2007 | 06:00 PM
82 vert's Avatar
94 opti re-install
hello everyone, johnny from south florida here with a quick question.
I am about to replace the front seals and gasket on the timing chain cover of my 1994 Z28. while there I will be replacing the timing chain for good measure. Now my understanding with this particular year is that there is no keyway (relocation slot) to re-install the optispark. After I position no. 1 cylinder @ TDC what else do I have to do to re-install the optispark correctly???
Old Oct 16, 2007 | 06:23 PM
Yes, there is a keyway. Look carefully as you pull it off and put it back the same way.
Old Oct 16, 2007 | 07:23 PM
94Camaro_Z_28's Avatar
It's not terribly hard to get it to line back up, just make sure it is. You can miss the keyway and feel like it's indexed, but when you tighten the bolts down it wont want to seat to the timing cover.
Formula Steve
Sep 19, 2023 08:31 AM
94Maroz28
Oct 27, 2015 04:38 PM
Ks0209
Oct 1, 2015 07:32 AM
colts0455
Sep 27, 2015 01:07 PM
jayblev95
Sep 26, 2015 09:44 PM
