94 manual firehawk
Old Jan 23, 2014 | 03:07 AM
grn94firehawklt's Avatar
Unhappy 94 manual firehawk
okay... I need help! I have a 94 firebird firehawk and it has a 112k miles on her. She's been starting up very rough and when i do get it started i get some white smoke along with a fuel smell and can't pinpoint my problem. After five mins or so it runs cherry. That was first problem with it. I drove it the other day to the gym parked it and then came back put and it wouldn't start, clutch in and turn the key i get a very un pleasant noise like something is grinding! I am praying that its just my starter and not my flywheel. Does any one have some advice for myself? Thanks
Old Jan 23, 2014 | 06:14 PM
Mr99SS's Avatar
Re: 94 manual firehawk
grinding sounds like teeth are hurt on flywheel ... any pics of the car ... I love hawks
Old Jan 23, 2014 | 09:40 PM
I added some pictures for ya bud. And the flywheel is what i was afraid of! How hard will it be to replace and you think id have to replace my starter as well? Its not even trying to.turn over before i hear the rough grinding! :/
Old Jan 24, 2014 | 10:32 AM
Where do you live? In extreme cold, it's normal to get white smoke on cold startup. It's just the water vapor, produced by burning gasoline, condensing.
Excessive fuel at startup can be related to the coolant tmep sensor, since that is what tells the PCM to enrich the A/F mixture for cold start. But if the sensor was indicating too low, it would seem to make it run worse when the engine warms up and the sensor is still indicating it's cold.
Old Jan 24, 2014 | 03:54 PM
Matts97camaro's Avatar
Nice Hawk, I checked out you pictures. Hopefully it will be a easy fix.
Aaront810
Aug 29, 2020 09:34 PM
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
Tarizza
3rd Gen / L98 Engine Tech
Sep 20, 2015 03:26 PM
plattted
9
Sep 20, 2015 11:23 AM
