94 LT1 starter heat shield
Old Feb 10, 2008 | 07:37 PM
mano's Avatar
Does anyone know if the started for a 94 LT1 suppose to have a heat shield on the selonoid. My car starts fine when you first start it but after a few short trips the car starts slowly like the battery is low. I have a new Interstate battery, also checked all the connetion to the starter it is good and tight. I was wondering if I need to put a heat shield on the selonoid or just get a mini starter.
Old Feb 10, 2008 | 07:43 PM
JooneJune's Avatar
New starter or old oem starter?
If it's the stock oem one, you mite need a new starter. These things go, but if it's new recheck your connection and invest in an optima redcap battery, its a great battery.
I haven't seen a shield on oem applications, i know my maro's didn't have them.
Old Feb 11, 2008 | 01:37 AM
GreasyB's Avatar
I dont think that the starter needs any sort of heat sheild. Sounds like you got other issues other then heat.
Old Feb 11, 2008 | 06:03 PM
red 95 z28 lt1's Avatar
how is the alternator output? whats it reading on the gauge? and put a meter on it when running, it should read about 14volts to ground
rjc1629
Jan 27, 2015 10:46 AM
Jan 23, 2015 01:13 PM
Injuneer
Dec 15, 2014 09:36 AM
ro2207
Dec 4, 2014 06:18 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
